I would bet this is a ground issue. There are several issues with all these types of boards
The copper gets corroded, the screws get corroded, and the casting gets corroded where the board grounds to the casting, AND the casting may lose ground.
The pins to the connector(s) become loose, corroded. Solder them to the board if you can
The spring connectors for the voltage limiter do not necessarily make a good connection to the board. I soldered mine to the board
The copper around the lamp sockets becomes corroded or eroded away, possibly from heat and or arcing
The studs/ nuts where the gauges connect suffer the same fate--corrosion of the copper / nuts and studs, or just plain loose.
