1964 Plymouth Valiant Convertible.
Back story: Problems with a constant voltage discharge. Replaced alternator, Voltage regulator. Added voltmeter. Went to bypass the ammeter by connecting up the wires. Did that and the convert top motor runs constantly. There were three wires on the back of the ammeter (2 black, one red). When I remove one of the black wires from the combination, the top motor stops running but now will not go up or down.
What appears to be the instrument panel voltage regulator is just hanging there. Not sure where it goes, none of the manuals I have show a good image.
The underdash is kind of a mess. I'm guessing lots of things chopped up over the years (wires going nowhere etc). Just trying to get it sorted out. I have a schematic but it doesn't show where that dang panel voltage regulator or the single balk wire should be.
I know this is a long shot but does any one have an image that shows this?
As always, thanks in advance!
