Intake Cam combo
72dart_swinger
I was wondering if the Weiand action plus intake was a good choice with a comp xe268 cam. Its in a mild 360 Dart that will be used for cruising around. Here are the cam specs.
Lift: .477''/.480''
Duration: 268°/280°
RPM Range: 1600-5800
I think its a good choice. Your cam doesn't operate in a high enough rpm range to warrant buying an eddy rpm. Plus its a good intake for what you paid for it...
Ha ha how would you know that:bootysha:
You should be fine thats the same intake and cam my friend is running on his "smog" motor 318 with 360 heads and has gone a best 13.75..not bad for what it is..
