3406pk
I'm in process of assembling my 340 engine, basically stock rebuild and using J heads and stock cast intake. The shield below the heat crossover is still in place and I wonder if it will leak crud/carbon out into new engine. Should I remove it or leave it. I am going to block off the heat crossover with the block off gaskets.
