dancinwulf
I was getting ready to put my 340 back together and noticed my intake manifold which was off of a slightly newer mopar has no rear water jacket holes in it they are closed off you can see
where they should be but the casting was not opened up there will this manifold work or is that going to be a major problem the gasket has the center exhaust port plugged which is fine since I only drive it in the summer anyway. Any help would be appreciated thanks
