psi_duster
testing with EQ magnum heads.
What the video is showing is the cfm flow of the intake and how it flows less than the intake port there by limiting the intake port total flow abilities. AKA, it’s killing HP vs what the head is capable of in terms of total cfm flow through the head.very confusing video...maybe i'm too thick? What is he saying?
The RPM will clear the hood on A bodies and the use of a drop plate air cleaner, like from Mancini Racing, will allow its use. I’m suggest you select an air cleaner but that is short and flat to clear the under hood insulation if you have it.good velocity though!And yeah.. having only one choice in dual plane sucks balls especially when the company and intakes are so badly made
If i end up with hood clearance i will probably end up with a single plane, i went RPM cause i have no idea on height yet.
yup, i'm in a 62 b-body but there wasn't much clearance when the poly was in there, with the stock setup.. will get the LA going with the rpm then figure it outThe RPM will clear the hood on A bodies and the use of a drop plate air cleaner, like from Mancini Racing, will allow its use. I’m suggest you select an air cleaner but that is short and flat to clear the under hood insulation if you have it.
the 62 has a pretty low hood line.. it's just one thing to figure out when i get to it.. i already have the rpm ready so.. no biggy at this point..For what it's worth I run a Hughes RPM AG with a 1/2" spacer, Edelbrock AFB and a '72 trap door air cleaner with no clearance issues. No insulation though.
That's interesting, my poly had like 1" and was bone stock.... BUT.. my 62 has the 61 k-frame and powerflite mounts, might sit higher maybe?@Icetech, I don't believe you will have trouble with the rpm on a small block in your 62.
Mine has a dart raisin bran scoop, but it doesn't need it for carb clearance. My 440 has a team G single plane, 850 brawler, and a drop base a/c that came with the carb, and I have plenty of clearance, even without the scoop.
Heck, I've had a maxwedge crossramon it, with all the hood bracing intact, but I wasn't running aircleaners at that time. Air cleaners may have been a problem, at least the factory max repops might have been.
That is distinctly possible. Mine has the big block k member, and I have the mounts , but I built some elephant ears for it, while it was sitting on factory mounts. Pretty sure it is at stock height.That's interesting, my poly had like 1" and was bone stock.... BUT.. my 62 has the 61 k-frame and powerflite mounts, might sit higher maybe?
NICE! I have a trap door air cleaner myself. Had two, sold one to Rani. It’s on my 5.9, in a ‘79 Magnum now on top of a RPM & Edel. 750. Good to know this stuff.For what it's worth I run a Hughes RPM AG with a 1/2" spacer, Edelbrock AFB and a '72 trap door air cleaner with no clearance issues. No insulation though.
Do me (Us the forum) a favor and find some clay to put on top & around the outside diameter of the high points of the air cleaner.
Measure them up.
Can do. Just need to find some clay.
Measure them up.
What is the stock head flow of the Magnum head?So on US stock Mag heads the flow would not be restricted by the intake in question?
So, since you guys know all this... is there any point to having a head that flows 300cfm if your intake can only do 240?
