Interior Color
WayneShelton
Spokane WA
Im getting ready to start painting the interior trim pieces such as the dash, glove box, ashtray, and other trim. My question is should I go with a gloss black or satin black.
Dash & some but not all other parts are suede.
What is your car type, model year & interior code?
SEM Landau black is nearly perfect match for those suede finish pieces you mention. Off the local shelf too. There isn't a supper high gloss anywhere. A-pillar trims, roof rail trims, kick panels, etc.., do have a medium gloss finish ( compares to vinyl with Armorall applied ). I can't say what is best for these pieces. I can only say supper high gloss appliance epoxy was a bad choice.
True. The interior colors are never all the same shades and no bright gloss. Sometime on feebay you will find the OEM paint chart for your car. On the back side it will give the recommendations as to gloss and the different parts of your car. painters refer to % of flattening agent applied to get the needed amount of NON shine!!
Inner door frame paint would be TX9, same gloss black used on a black cars exterior.
In a Duster, same for the removable C shaped panels that surround the inside of the rear pop out windows.
There is a 1971 exception though, TX8 - charcoal.
It was used in the same spots I mentioned above, but I forget what option it tied too, blacked out hood maybe.
