Iron adjustable rockers and cam change
jeffnmo
Just another Mopar Maniac
south carolina
I've changed a few cams but kept the stamped rockers, this will be the first with Crane iron adjustable rockers, when I adjust all the rockers won't I wipe all the cam lube off? Using the Mopar valve adjustment chart. I know its been done, am I just being a bone head and having the cam brake in jitters?
Jeff
If it comes off that easy, you are using the wrong lube lol. Youll be fine.
Thanks Guys, I knew it would be fine but just had to ask! by the way I'm using Driven assembly grease and break in oil.
Jeff
The extra lube You Don't See has been caught up on the bottom of the lifter right where the cam touches it underneath. it's all balled up right there where you want it...
Any decently thick cam lube just piles up under the edge of the lifter... as shown here with Crane cam lube after a few rotations on the engine stand:
Thanks nm9stheham for the photo, makes my brain feel all better now! Thanks everyone else too.
On to getting the Beast back on the road, Also putting on the LA-X heads from IMM.
Jeff
