Badart
Senior Member
Fired my fresh 318 tonight to break in the cam on my basket case dart. Easiest start up I have ever had. Fired on the first hit, checked the oil pressure, set the total timing to 36 degrees and adjusted the throttle. I was able to run the engine (guessing about 2500 rpm, because no tach installed yet) for about 10 minutes, then I saw the temp creaping up around 220 degrees so I shut it down. I figured I would have some air pockets in the cooling system so I added some water. Went to start it up again and my battery was dead. I guess the alternator is bad. Charged the battery and ran for another 10 minutes from 1000-2500 rpm. Is this enough for the cam break in? I used comp cams lube on the cam and lifters and VR-1 oil for the break in.
This little 318 sounds mean and revs quick.
Here is my set up. .040 over flat top pistons .060 in the hole, Comp XE256 cam, Rebuilt magnum heads with 1.6 rockers and chebby behive springs, Magnum dual plane air gap intake, Holley 600, Hooker comp headers. Flowmaster 3" 40's. Should be a fun little street motor.
I will try and post a video over the next couple of days.
