ValiantOne
Hey all,
Does this look right? Seems like it's stretched out to far. Yes , no?
Thanks
CE
Thanks
CE
Matt, I'm going to email a picture over to Wayne at Brewers and see what he says. I'll report back.Interesting. Subscribed. Going with same exact setup in my 67 cuda. Chris drop me a line when you figure out which spring PN# you end up needing to use.
Cool, thank you bro!!!!
Looks good. I looked up a few different suppliers and the small block springs all had aprox. 16 coils and it looks like you have it installed correctly.Like this? Better but still seems stretched out to far, no?View attachment 1714941792 View attachment 1714941792
Well, Wayne says it is the right spring and installed correctly.
Matt, i actually bought this kit, but you can get the spring separately of course.
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
I was sure hoping somebody would post a pic of theirs.
Got the kit from BREWERS
I drilled a hole in the z bar as well. not hooked to the block like yours. I cut and rewelded my z bar to clear the dougs headers. so the way mine is setup is not factory by all means.Looks like mine is adjusted much further out than yours. I do need a bit more freeplay in my pedal. Maybe that will make up for some of it.
Thanks!
CE
Looks like too long of a adjuster. Not a problem just too long.Looks like mine is adjusted much further out than yours. I do need a bit more freeplay in my pedal. Maybe that will make up for some of it.
Thanks!
CE
