Is my ring gear pattern acceptable?
standup303
Colorado
What do yall think?
Nice job, looks good.
You can tell if you have it too tight after you run it for a short distance. You can feel the bottom of the 3rd member and it should be warm to the touch, if it is running hot to the touch then your ring and pinion adjustment is too tight or not enough backlash.
Good Luck
Good Luck
Thanks I’ll check that once I get the car out.
