Is there a difference application for these 2 clutch forks?
Rocket
CT
I have 2 clutch forks. Does anyone know if the slight differences matter and what applications they may be for? See shape near where linkage rod bolts on. The painted one also has a notch on one side near where the linkage rod goes in. The unpainted one has two cut outs near the end where the linkage rod bolts on. It is also a little wider on the side versus the painted one. Both are the same length of 11" end to end.
The one in my SB Duster looks like the one pictured except it has doesn't have the hole drilled in it because the end broke off. The slot is for a spring mount. The spring goes from the clutch fork to the z bar to keep the adjustable rod snug against both sides. I don't know about the other fork. I could have used the one on the right about 3 months ago.
I have 2 clutch forks. Does anyone know if the slight differences matter and what applications they may be for? See shape near where linkage rod bolts on. The painted one also has a notch on one side near where the linkage rod goes in. The unpainted one has two cut outs near the end where the linkage rod bolts on. It is also a little wider on the side versus the painted one. Both are the same length of 11" end to end.View attachment 1714949403 View attachment 1714949404 View attachment 1714949405 View attachment 1714949406 View attachment 1714949407
Top picture, the one on the left fits 62-5 B body along with most C body and A100 trucks/vans. The one on the right fits 66-74 B/E body along with A body Big block.
