is there a write up for an 883 SB swap??
eviper21
SoCal
I have a 73 duster I'm swapping from a slant 6 to a 318. I want to convert it to 4 speed but theres so much information mixed up everywhere. Is there a write up on whats needed to make the swap?? Or can some one just give me a list? lol
thanks!
Call brewers performance or browse their website for everything needed to install the A-833 four speed.
You will need the bell housing, clutch set up, transmission, linkage, shifter, four speed hump, bell crank pivot ball for frame rail with reinforcement plate unless you go hydraulic.
Trans mount...etc.
Easy swap really, I got stuff from Brewers, they know their stuff and have great stuff!!
your 318 crank will have to be drilled for the 4 speed if its not.
you can also use a newer magnum pilot bearing that rides inthe converter hub location instead of drilling
