link (i think that's what it is ) for a dart . If I had that my pipes from my short tube headers could pass over the steering instead of under .
or is this not possible ?
jerry6
I do believe the '73 up centerlink mounts differently .The '72 and earlier version sits atop the idler/pitman arms the '73 and up sits below them .not sure how much more room that would allow.It may be worth looking into.But the Idler/pitman arms would have to be changed at the same time.
No, there isn't. But, like said above there was a change that does affect some fitment issues, but you will be unlikely to be able to make the swap without also changing the steering gear.
if you do swap to 73' up, you could also get the FirmFeel pitman and idler arms "The fast ratio pitman and idler arms are 1 1/2" longer than the stock arms".
that may or maynot move things around enough for you
