Is this a good 340 combination? How much HP?
65s
Ottawa, Ontario
Do you think this is a good 340 combination? This motor is for sale locally and I'm thinking I should buy it. Not sure yet how much mileage is on the motor, but I'm going to find out. What does he mean by water jack filled?
1971 Mopar 340 4-Barrel Motor
Block: Mopar 340 block (water jack filled)
Deck Height: 9.00
Bore: 4.040
Stroke: 3.31
Crank: Mopar Forged (stk .013/.010 mns,.020 rds)
Rods: Mopar HP
Pistons: Badger, 10.5-1 comp. Tool steel pins.
Rings: C&A file fit
Oil Pan: Mopar 6 quart
Oil Pump: Mopar Performance
Pickup: Mopar
Damper: Fluidamper
Balance: Internal
Camshaft: Mopar 256/265 @ .050 camshaft
Lifters: Schubeck lifters
Pushrods: Mopar HP
Timing Chain: Mopar HP
Timing Cover: Mopar
Water Pump: Mopar HP
Head Gaskets: Fel Pro 1008
Cylinder Heads: Mopar stock CC heads
Valve Springs: Mopar HP (180 closed X 300 open)
Retainers: CV Products Chrome Moly
Locks: CV Products Chrome Moly
Seals: Fel Pro 11/32” Rubber
Seat Cups: None
Rocker Arms: Mopar HP
Valve Covers: Mopar chrome covers
Intake Manifold: Mopar Thermoquad spread bore
Manifold Gaskets: Mr Gasket #307
Carburetor: * Thermoquad (750 CFM) Carb.
Distributor: Mopar HEI ignition
Spark plugs: Autolite AG-52 gap@.045
Carburetor: Thermoquad (750 CFM) Carb. By The Thermoquad Connection
Well if the deck height is really 9.0 inches allot has been milled off. Stock is 9.59-9.60 so approx. .060 is milled off. Completely filling the water jacket isn't good for a street engine at all. Means no coolant can now flow around the cylinders. It's my understanding that you only do that on a race only block. You can partially fill a jacket on a street car but I'm not sure how much is ok. Maybe if I'm wrong somebody will correct me.
That's a whopper of a cam too especially with stock heads. Unless your running a 4,000 stall and low gears it won't have much guts on take off.
I'd keep looking but that's just me.
A half fill of the water jacket would be OK for the street.
I believe that Badger only makes cast pistons.
Chuck
i would think that this has to be a miss print because that is .600 which would be over a half inch.
That is a lot of cam and... Schubeck lifters - tried TWICE .... I could not get them to live on he street - kept wearing down the lobes.
Kory
This is exactly the stuf I needed to hear. I didn't know about the deck height or the water jacket filling...this engine is not for me, that's for sure. Thanks a lot!
65s
Stock stroke, stock bore, badger pistons and a hard fill????
Those things don't go together in my mind.
Sounds like it might have had a crack somewhere... in any event, filled blocks mean one of two things. You're running alcohol for fuel, or it's a coffee table.
