Cythomas
Active Member
I figured this is garbage just asking
Is it a 360 crank? Guessing time I take it. Well if so the rod journals can be cut down .010-.040 or maybe even more if bearings are available. Or to Chevy size. The main bearings under .020 are harder to find.
Check out post 102 in this thread by RustyRatRod. Excellent writeup with video on cleaning the rust off a crank.
Then ya grind it to the 340 main.
Lol you can save 'almost' anything.
As long as it's not bent, it'll clean, or build a "349", "372".Then ya grind it to the 340 main.
yes 360 crankIs it a 360 crank? Guessing time I take it. Well if so the rod journals can be cut down .010-.040 or maybe even more if bearings are available. Or to Chevy size. The main bearings under .020 are harder to find.
Well, in that case..yes 360 crank
Scrap it and put a 408 crank in
That trick only works if it’s a forged crank. Kimassuming its not bent or cracked just about anything can be saved as said before. easy way to check for cracks for free (not fullproof and should also be verified by a machine shop) but if there are large cracks you should be able to "hear" them. Take an open ended wrench or small piece of metal and just tap on the counter balance weights up and down one at a time. The crank should sound like a tuning fork if all is well. If it doesn't have a nice consistent frequency up and down then you likely have a crack somewhere. If it passes this test then you can continue with the rest of the process of cleaning up. A friend of mine who builds engines for a living does this when people bring in their "good" cranks, taps it a few times up and down before even starting, if it has a crack he usually finds it in seconds, if it all checks out then he pulls out the real equipment to start checking everything
OH! Thank you! I had no idea it didn't apply to cast cranks either! I learn something new every dayThat trick only works if it’s a forged crank. Kim
