Is this correct?
Stroked68Dart
402 Crate Motor in a 68
San Francisco Bay Area
Are these vacuum lines connected correctly? I have a Mopar Performance vacuum advance distributor, a Holley 4160 single pumper with vacum secondaries and electric choke. There is one vacuum line that goes from carb plate to both the choke and to the distributor via a T connector. Please see below photos and let me know if this is correct.
Thanks in advance.
Bill
where the black cap on the carb metering block is...that hooks to the distributor's vacum advance....then plug the others...
