is this lug pattern right?
wstcstjunkie
69 Dart Custom
Hemet, California
ok, i was going to replace my rims until i noticed something different. the front wheel studs looked further apart than the rear. is this normal for a 69 dart custom 273/auto? looks like 5x4.5 in front and 5x3.75 in the rear. it has what i thought was factory disc brakes, maybe some put the wrong rotors on? please provide you assistance.....
Do you have an 8 3/4 rear?Maybe time for some large bolt pattern axels?Or you could drill your axels and drums for LBP.
here are some pics, so i need to find an 8 1/4 rear from another A body, any other options?
You have a working rear end in your car, so I would just redrill the axles you have, or buy yukon / moser aftermarket axles and put them in ( if you have the 8-3/4 rearend )
8 3/4 aftermarket axles will require new backing plates from an large bolt pattern rear end. like a 8 1/4..along with drums..
You probably have the 7 1/4 rearend, I'd do the junk yard sourced 8 1/4 rear swap.
