Is this what I need?
Coyote Jack
Member #55, I'm old
Baxters Corner N.B. Canad
Is this the fitting I need to connect to the OEM brass fitting at the tranny and the radiator?
http://store.summitracing.com/partd...art=SUM-2200075&N=700+400304+115&autoview=sku
Jack
Jack, those won't connect direct to the brass fittings on the trans and the radiator. Those are meant to connect to a hard line by means of a compression sleeve - you'd need to cut the existing hard line and then use these to connect your braided line to the hard line stubs.
Wrong part Jack, that one is for a hard line! On the radiator end though you'll need another 2 fittings to go between the new hose end and rad.
For the rad times 2
http://store.summitracing.com/partd...=SUM-220648&N=700+4294849624+115&autoview=sku
The cheapest hose
20 feet http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-230620&N=700+115&autoview=sku
For the Hose Ends times 4
Greif relief LOL
http://store.summitracing.com/partdetail.asp?part=EAR-184004ERL
That will get you all set for the cheapest prices that I know of.
:cheers: Eric
