I'm in the middle of moving and we put some crunch time in the last few days to get the long block together, mated it to the 4spd OD and got it dropped in last night. Today is the big move day and I'll get it into my new garage with a plan of finishing it this winter and back on the road next spring.
Final build specs: 1970 Barracuda, 4spd OD, 8.75 w/3.55 gears and a sure grip. Original 225 bored .040 over, shaved .030 off the block and .060 off the head, mild port work and gasket matched (stock valve size), 340 springs, JP Performance DBL roller (I ended up having to shave 0.090 off the back side of the crank sprocket to get proper alignment with the cam gear), Offenhauser 4bbl, Eddy AVS2 500, Clifford shorty headers, HEI distributor setup from Ray. RAM HDX clutch and flywheel setup. That's the main stuff, I'm sure there'll be some other fun this winter to figure out.
