Jeep Liberty rear discs
dusted72
Thanks Hemiroid!!!!
Triangle, V.A.
Has anybody ever tried to use the Jeep Liberty rear discs. It is a 8 1/4 axle and has 5x4.5 bolt pattern. It also just bolts on and the e-brake is a drum style setup. Reason I was wandering is because I just did the rear brakes and it got me thinking.
Iwas wondering the same thing about the grand cherokee. but never got around to accually doing the home work yet.
The grand Cherokee is supposed to be a direct bolt on with only one hole having to be drilled. The 8 3/4 has a 5 bolt flange and the Cherokee and a 4 bolt the original 4 line up you just gotta drill one for the 5th.
There is more to the GC than just drilling another hole-----something about 3/4 space from the axle flange to the axle housing, there is a thread about it here somewhere.
