JeffreysDart
my 69 Dart rear springs are looking limp and flat... i want to get that *** up in the air with a mean raked look!
What do y'all recommend?
Air shocks. They are like 80 bucks and you can fill them up/deflate them to your desired ride height.
Get some good leafs. I wouldn't do air shocks.. Harsh ride and if one line blows your screwed.
:happy1:Yes Big B Barracuda, what is your set up?
700 pounds of air pressure then load 5 dead bodies in the trunk.
Super stock springs. The 002,003
Put a bar of soap in front of it?
I put those bolt on booster leafs to stop a little rubbing. You can barely see them and they aren't radical.
New springs are the way to go. Mopar's upper shock mounts aren't designed to carry much weight. Espo will get you what you need. http://www.springsnthings.com/
WHAT SIZE on the rear tire and wheel?:coffee2:
