John sent me his bad luck!
EvilScamp
Dalton PA
Last weekend i started putting some of my Duster back together,doors,right front fender,trunk lid.
Doors and fender went together well got to the trunk lid got it lined up good gaps were straight latched good then i noticed that between the key lock and the center of the right taillight there was a 3/16 overlap of the trunk lid over the taillight panel! WTF?
Started measuring and somehow the taillight panel was pushed in,how or why i never seen this i have no idea.
I got it pulled back to where it should be but in the process i created another problem.
I had replaced the right taillight part of the panel and while pulling it out i cracked the body filler and after grinding off the filler found i had also cracked the weld about an inch and a half.
On Wed. i took my brother to pick up his new truck stopped at the red light a block from the dealer the brake pedal drops and the brake light comes on,i popped the steel brake line,behind the gas tank!
Since i didn't have time to fix my truck i been driving my 72 Duster,went out this morning and it had a flat tire! <IMG alt=">:-| " src="http://www.smileytown.com/application/content/angr0008.gif" border=0>
Wow....sorry to hear about this. I'll have a chat with those little bastards and tell `em they were supposed to stop in New Jersey, NOT Pennsylvania!
Good luck Kev, and remember....breath in slowly...breath out slowly. Then take a hit & a swig... \\:D/
Tell that when they get to Joisey to visit my pal Tony!
HUH!! What!!!
Boys, you just got to heat'em up and spit them out!!!! :-\"
man i hate that, whenever something goes wrong everything that is associated with it will go wrong, like my fender patch, didnt line up, cut off parts of the old fender, still dont line up...awh i hate going threw this again, at least the other fender didnt seam like this big of a pain in the ***
Kev, you are talking to John way to much. It is rubbing off. I know how you feel though. I was out in the garage the other day just looking and planning. I noticed that after all of my work on the left rear quarter that I welded it on an inch to low. Now I have to take it off again, clean it up and put it on right. #^$@*&^% This is all after I start the engine again with the 3rd cam.
Jack
