bone stock rebuild???
$1,000
if you want to start porting/polishing heads and stuff then the costs begins to escalate QUICKLY
go to summit and check the price of a master rebuild kit bout $400, right?
add in cost for machine shop to:
bore/hone/magnaflux block
grind crank .010/.010
regrind cam
"go through" heads but many times that doesn't include replacing valves (they usually just grind them for $1,000)
for this $1,000 they don't balance anything either as these engines weren't balanced from factory and they figure the replacement parts should be within range of OEM parts
you can get a longblock from Pep Boys for $1,200 I believe
At least that's what I remember what a 360 longblock was going for about 6 months ago.
my figures are in the San Diego area.
EDIT:
I never understood how a $1,000 stroker kit can become a $3,000 shortblock
$2,000 in labor and machine work on the block i guess
