TrailBeast
AKA Mopars4us on Youtube
This kinda sucks because I have this issue that everone say's "Gees, I wish I had that problem"
I had the original 18" radiator and all OEM cooling on my Dart 318 and it would get pretty warm (210-220) in parking lots and slow block to block driving.
I replaced the radiator with a 26" Extra cool 2 row model and got a Jegs 17" electric fan, 8 impeller water pump, and a new 195 thermostat.
The fan controller starts the fan at 210 degrees and shuts down at 195.
All this works great around town block to block and idling around parking lots at low speeds.
Now here's the problem.
Even if it's 80 degrees outside if I drive down the hiway for even a mile or two, the engine temp drops to 165-170 degrees.
I blocked off the bypass from the water pump to the intake thinking "maybe it just cooling enough that the bypass was letting cooler fluid past the thermostat"
Didn't help.
I've been through all the guesses and thought I would ask if anyone KNOWS why it gets down that cool with a 195 thermostat in it.
Thanks
Didn't help.
Thanks
