Jim Batchelor
Jim Boy
I have a question, hope someone can answer it for me. I have a front end that came off of an original 1969 340 Dodge Dart and I have a 1975 Duster. Will the 69 v8 k-member fit on the 75 duster??
Why do you want to swap them? The 69 K-member uses different motor mounts, the 73-76 k's use a different spool type mount which is actually better...they also use different sway bars on the 73-76 cars too. If you only want to swap it in cause you are going from a slant 6 to V8 then I wouldn't waste my time, instead buy the S6 to V8 conversion motor mounts and be done, way less work and the fit is usually really good.
On a 73-up k frame,1) I don't have to lay under the car to loosen the engine mounts. 2) they sell urethane mount inserts.3) even if my mount fails my engine will stay in place. 4) they had a better sway bar set up which are all wins to me. I have spool k frames in both of my 67 Valiants. I wouldn't toss a 72 and older one but I prefer the spool type.
