mullinax95
I had a 273 in my car in which the radiator is two core stock type unit with no shroud. The dang fan and the upper radiator hose has only 3/8" clearance between one and the other!! Disaster waiting to happen. I wouldn't think a shroud would fit between the two witout trouble. I don't believe it is the correct radiator. The inlet and outlet are both on the passenger side. ??? Now I have a 360 cammed up, bored .030, headers etc..
Right now the hood is still off and I have no cooling issues and it has been hot outside. The temperature gauge stays around 180*. Now when I install the hood I think I might have a cooling issue.
I can get different radiators with more cores and run the stock clutch fan and hope for the best. BUT heres the kicker. I have bought March serpentine belt type pulleys and the water pump pulley comes with a cap in order to do away with the clutch type fan if I want to. I would like to go with a electric fan but there is not much room between the radiator and the cap when mounted. 2/34" is all and there is not much electric fans that will fit that make much cfm. They make around 1250 cfm and I just don't believe that would be enough.
Or will it?
I found one electric fan that might fit that makes 3250 cfm and I would try it first.
Thanks
What do guys think I should do?
Or will it?
Thanks
