snailpower
Im assembling my 99 5.9L with a kevko pan and their pickup for mostly street, some strip use. The mains and pistons are already in and I am reusing stock main bolts.
The problem I am having is that the kevko pickup has the tab attached to it but there is nothing for me to attach it to since I am not using aftermarket main studs.
I called kevko and asked about just cutting this tab off and running it, he advised against it as the pickup would probably break off. This seems unlikely to me as the stock pickup doesn't use this type of setup even if the kevko pickup is longer.
The other option would be to get a single stud from Napa and use that but I would prefer not to remove the main again if avoidable.
What does FABO say about how to handle this ?
