Hello all
Ok, So I been saving up for some years now to build a Dodge 360 LA series. Well I bought a motor off a buddy, and bout 1500$ worth of bearings and comp cam kit. So I took block and heads to the machine shop. Machine shop told me to many cracks in the in the heasd, and block was salvageable but needed to be bored out.
I am looking for the cheapest way to fix up a decent motor. Can I get a magnum block and heads from the running durango, ram, jeep Cherokee etc. and use the XE268H Comp cam? and bearings?
This is major parts that I have.
Bearing Set
4 inch pistons
20-223-3 XE268H Cam Kit with chain
professional prodecut air gap intake
650 Cfm carb double pumper.
Can I use the LA block with mag heads? with a carb?
Any input or suggestions would be great!
Bearing Set
4 inch pistons
