LA serpentine
stupidasso
CA ANRCHY
Oceanside, CA
Hi all,
Does anyone know if Dodge put a serpentine on a 5.9 LA engine prior to 92 when they went to the magnum? if so, what year and model did they do this on?
Thanks,
Stu
I believe or have heard of people using the magnum setup on a LA engine but you have to use the magnum water pump also because it is reverse rotation.
And ethier space it our because the LA timing cover is thicker or use a Magnum cam with the stock Magnum cover and switch to a electric fuel pump.
stupidasso said:
yeah, looking to not spend a grand on a belt system.
The March serpentine pulley system is nowhere close to a grand. I bought the pulley setup for my Cuda and only paid $300 bucks for it at the local speed shop. Would've only been $225 but I have PS.
