Larger bolt pattern spindles
mhuppertz
Tijeras, NM
So if I want to put an 8 3/4" in the back and want discs and the large pattern in the front, what do I need to look for in the boneyard?
Get a B body rear end, move the pearchs in 1/2" and different backspaced wheels. That or an A body rear end, call up Dr. Diff and order all you need from him. He is a good guy and won't do you wrong.
73-76 A body disc or FMJ spindles will work as long as you have the large ball joint upper or sleeves for SBJ set ups.
