Yunick13
3 Time FABO NASCAR champ 2023 FABO NHRA champ
Ram calls it Deep Cherry Red Metallic. Need to get some mudflaps for it. It didn't stay clean for very long.Nice truck and love the color.![]()
I get a kick out of all of the paint names. I just did one called solar octane.Ram calls it Deep Cherry Red Metallic
I think the law requires rear mudflaps.Ram calls it Deep Cherry Red Metallic. Need to get some mudflaps for it. It didn't stay clean for very long.
Our 300 is the same colourNice truck and love the color.![]()
Stuck valve? Or?Ready to feel more low end power. Ditched the single for a dual plain air gap. Bulling the 20 year old lifters for new, found out what my tick was, must likely happened at first start up after setting for years. My day
What the hell you going to do with all that money Fred. Guy I sometimes work for called me the other day. Asked if I wanted to work framing a basement out. I asked is all the material down there. He said no, I said same answerGood morning all. Not much to report it's another off to work day.
Just trying to pay my home loan off as fast as I can.What the hell you going to do with all that money Fred. Guy I sometimes work for called me the other day. Asked if I wanted to work framing a basement out. I asked is all the material down there. He said no, I said same answer
now if ya put some wicked flames on it, I'm sure it will go faster...
Careful with new lifters. Most are junk. Have the new ones or old ones refaced or you may have an issue.Ready to feel more low end power. Ditched the single for a dual plain air gap. Bulling the 20 year old lifters for new, found out what my tick was, must likely happened at first start up after setting for years. My day
Thank you, yes I agree... have set aside 13 good ones that pumped up good, all my surfaces areas look real good and flat.Careful with new lifters. Most are junk. Have the new ones or old ones refaced or you may have an issue.
New lifters old cam ok, new cam old lifters, no go. Never had much problem with lifters. Took the factory cam, lifters, push rods and rockers out replaced it with flat tappets. Had engine apart twice after no problems with valve train.Careful with new lifters. Most are junk. Have the new ones or old ones refaced or you may have an issue.
Appears that the push rode danced out of the rocker seat once or twice. Sat 20 years and that lifter was not pumping up, dew to crud from it long nap it took.Stuck valve? Or?
Actually not flat. They wont spin on the cam lobe. They should be slightly domed. If put on a flat surface they should slightly rock.Thank you, yes I agree... have set aside 13 good ones that pumped up good, all my surfaces areas look real good and flat.
Thank you Chief![]()
Most important though is good oil, find one with all the bad stuff in it, all the heavy metals, zinc etc. Driven is the brand name I use $$$$$ but worth it. Forgot to hook up oil pressure gauge line went to prime engine that oil sprayed out hit the ceiling and all over windshield. Half an hour, can and1/2 windex windshield was clean again ugh.Appears that the push rode danced out of the rocker seat once or twice. Sat 20 years and that lifter was not pumping up, dew to crud from it long nap it took.
I will check my new one that soaked over night about 10 am, looking at my old ones, no wobble.. now this is an OEM stock lifter I have been running, put out 170.00 for these. Never over 55 hundred rpms.. prices have been NUTS.Actually not flat. They wont spin on the cam lobe. They should be slightly domed. If put on a flat surface they should slightly rock.
Hope you gain some torque Mike.Ready to feel more low end power. Ditched the single for a dual plain air gap. Bulling the 20 year old lifters for new, found out what my tick was, must likely happened at first start up after setting for years. My day
Hey Charlie Happy Birthday my friend. Cheers to ya...Going out for supper tonight. It's my Birfday. Started celebrating a little early. Wife's turn to drive. I qualify for social security but thinking about waiting until 65. That's when Medicare kicks in. Had to cook my own cake.![]()
