LCA Pivot Needed
photorep
los angeles
Hi: I need a lower control arm pivot...1974 Plymouth Scamp. A shop messed mine up when they were pressing it out. Left side. If you have one let me know...I Appreciate your help. My suspension rebuild is at a standstill until I get this.
I believe that Just Suspension stocks them if you're in a hurry
I ordered some new ones, they are 80.00 if I remember. Check your K frame bushings, they tend to get VERY eggshaped! I'm rebuilding a 68 Kframe and drilled mine out. I took the tubes to a machine shop with the pins and they're making new tight bushings for me. I'll weld them back in and see how much difference there is in the front end.
Hi Metallidart...I just need the actual spindle that mounts into the lower control arm and bolts through the k member.
The one that gets pressed in with a sleeve, rubber bushing and inner sleeve. I am not sure what you mean by.....the part that goes inside the bushing....thanks
Here is the part I need..thanks
Thanks HawaiiDuster, but the one in the picture looks different from the one I have. I am not sure it would work
Sorry I didn't get a pic, got carried away remodeling a room. Stupid wiring. I got one, $15 shipped if you want it, or $20 shipped for the pair. PM me if you are interested!
