furyus2
I have had a lot of success in doing it a different way. Since I don't have a press, I drive in the bushing then I put a deep socket I the back side of the lca. It needs to be the diameter of the inner bushing sleeve. Turn the lca back over, and put the pivot pin in the bushing, and using a pipe that fits against the pivot pin Ridge, I tap it in place. Done several like that. If you try to drive or press the pin without the deep socket to support the bushing from the back side, it will destroy the bushing.
