daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
As title says. I’m curious how they compare to the new Eddy RPM and Airgap. What are they worth these days?
Oops, think you ment LD4B for the 318 small port heads.It's an LD340 for the 318. That should tell you all you need to know.
Sorry Rob.It's an LD340 for the 318. That should tell you all you need to know.
Sorry Rob.
LD4B for 318. Like George Jets said.
LD340 is the large port manifold for the large port 340/360s.
Like the LD340s for the 360s, but are they ever getting expensive if you can even find them anymore. Cool if you want to go old school too.
I get it, but every LD340 I have seen is the large port manifold, bolt them on to a 318 small port head engine and you get a lot of turbulence when the port flow of the large port manifold hits the square edge of the smaller 318 head port.There was no oops. It's the 318's LD340. I said it like that on purpose so people would know that it is JUST AS GOOD FOR A 318 as the LD340 is for the 340/360. Get it?
All about port velocity and smooth port flow to make those 318s run like the wind.
It's the 318's version of the LD340. Separate intakes for the designated purposes.Well duhh. That's why I said it's an LD340 for the 318.
You are absolutely correct! And I'm an idiot! ;)Read what I wrote. I said it's an LD340 FOR THE 318. In other words, it's real close to the LD340 but FOR THE 318. It has 318 sized ports, so it's FOR THE 318. It's designed SIMILAR TO the LD340, but made FOR THE 318. Which is what I said. Thank you drive through. ;)
Don't everybody agree that I'm an idiot at once!You are absolutely correct! And I'm an idiot! ;)
I KNOW that you knew the difference, I just figured you had a typo or something.No you're not. Not at all. Yall were just tryin to make sure I wasn't an idiot. And trust me, it happens a lot. lol
Exactly. Thanks for understanding.
If you look closely the ld340 is ported a little different on a couple of the rearward ports works the same though.
