Leaf spring bushing
clhyer
Any tips or techniques for replacing the front bushing? The FSM says to install it at the same time you remove the old one, using a special tool of course...
That outer sleeve looks pretty thin, and the rubber sticks out a fair amount past the sleeve, looks like it would tear the rubber loose before you actually started to move the sleeve.
Any tips appreciated!
C
Crackedback, thanks for your response. Unfortunately I am not familiar with the term "Jackbolt".
Can you elaborate?
Many thanks,
C
Long piece of all thread, two nuts, wrench, washers, piece of pipe large enough in diameter and tall enough to allow the bushing to pull in to, and a air gun.
Pull it through
Thanks again folks! I was concerned because that outer shell seems so thin, but it can be done.
C
