Leaf spring help
lol..what a fiasco this is turning into. SO, I am going to use this spring relocation kit BAC A Body Leaf Spring Relocation Kit - Bergman Auto Craft
The kicker is that it uses 1/2" eye bolt size. Ok, BUT every place i have looked is OUT of stock on A-body leaf springs with the 1/2" eye size..BUT they all have springs with 5/8" eye size in stock..RRR, I know we talked about drilling the holes out to 5/8" in the OEM front hangers, but with this offset kit having 2 holes on each side for different ride heights, im guessing there is not enough meat there to drill the holes bigger safely..? Waiting on an answer from Pete on this but i bet he says no, theres not enough meat to drill them bigger..Just looked at this kit again and couldnt drill bigger anyways because it comes with the 1/2" bolts with flat tops for clearance of the frame and the new bushings..so there goes that idea anyways..here is all that General spring has..notice the springs with the 1/2" eye are out of stock, along with mancini, etc..I cant wait 5 months for ESPO Search
Ok, I'm done. You're makin this so much more difficult than it ever needed to be.
i think thats spring eye opening not bolt. meaning his bushing will fit into the 1.5" spring opening. i can't see him selling stuff with only a 1/2" eye bolt. pictures are hard to see but that look 5/8 to me.
Look at these springs that general spring offers for the A-body..several with 5/8 eye and one with the 1/2 eye. Pete said the 1/2 was stock on A-bodies and i think aftermarket sizing is 5/8?
Search
cmon man, what do you mean? ?Look at the kit, it has special flat headed bolts on that front hanger to get it close to the frame..I dont think i can find that same thing in 5/8 as he makes these kits..
Then do what everybody else did before the fancy flat headed bolts. Mark the frame rail and drill a hole in it for the bolt head. People have been doin it for decades. Oh and General Spring has TWO part numbers with 5/8 front bolts.
ok, i didnt realize thats what has been done in the past..first time doing this so please bare with me..without yalls help i wouldnt be doing it..I know general spring has the 2 part numbers for the 5/8 springs, thats what im probably going to get is their 2.5 added height spring and if its too high, use the second set of holes on that mount.
..and if you don't want to do that, then take a hacksaw and cut the bolt heads thinner. Heck, do I gotta come drink your coffee for you too? LOL
With a little creativity and old fashioned hotrodding, you can do almost everything that $500 kit does for free.
Yeah and certainly in no way shape form or fashion am I knocking anything Bergman has, but IMO, he doesn't need all the spring slider stuff.
I get that some people like bolt-in options. But to install that kit, you still have to doing some cutting and welding. At that point, few re-drilled holes and you can re-use the stock front and rear hangers and damn near be $500 ahead - minus a set of axle saddles. To each their own I guess.
I get that some people like bolt-in options. But to install that kit, you still have to doing some cutting and welding. At that point, few re-drilled holes and you can re-use the stock front and rear hangers and damn near be $500 ahead - minus a set of axle saddles. To each there own I guess.
well explain..lol..Either way, i have to cut the perches off , move them over and weld them..
Exactly. If you're looking to relocate your springs inward against the frame rail, re-drill the front hanger bolt holes inward. If you want to flip them to lower the ride height a little, be sure to account for the difference in bolt spacing on the hangers. For the rears, the bolt holes are offset. If I recall, you flip them and swap sides (or something like that), then you can reuse one the the stock holes. You just need to drill one hole and get a nut behind it, and voila - cheap way to gain a little tire clearance. Dr. Diff actually told my of that trick when he was out of his kits. In fact, he recommended it instead of waiting for his kits to come in. Of course some will say it's "hacking" the car up. To me, it's just hotrodding. Good luck.
Search
i think slant 6 were 1/2" and maybe 318 cars. i know when i ordered the 6 leaf V8 (what i'd ask for) from espo they were the 5/8 and the eatons i got from pete years ago were 5/8. I'm pretty sure those brackets use the 5/8. but let pete tell you for sure. he usually gets back to you quickly. @BergmanAutoCraft
Ok. So fair enough. Then let me ask this. That's gonna require a LOT of tire. Why not just do the 3" relocation and mini tub it?
Dont want to go that far into it. I have some 255/60/15 i put on today and its quite a bit more tire..looks much better also. The right side barely..BARELY scrubbed the inside of the tire against the leaf spring a few times..probably in a hard turn. It may or may not ever be enough to hurt anything but im pulling it apart anyways to install new leaf springs so may as well do the offset kit. I got some 1/4 spacers for that one side but i dont feel right about using them..not enough lug left sticking out for my liking..
I gotchya. Then here's what I recommend. CALL Peter Begrman. He is a GREAT guy! Tell him what you want to do and what you want your eventual outcome to be. He'll tell you his recommendation.
RRR you got me to thinking hard on this..why am i going to bother to do the offset kit when im only having the slightest rubbing issue against the leaf spring 'sometimes' on that one side..literally another 1/16" would probably stop it from ever happening..the axle may slide over that little bit on the new springs when i install them. the other side had more clearance anyways..
Now you're usin your noggin. I'm not tryin to talk you out of something. Do whatever you want. If you really want to hook that much power, I honestly think you can do it in the stock wheelwells with everything in the stock position. They make some really badass drag radials these days that really bite hard. You can make some measurements and figure out what the best backspacing and width to use. You can get this tool and find out exactly how big a tire and wheel you can fit.
Then there's the problem if WHICH stock you're talking about. There' stock slant 6 stock V8 and then comes the XHD which is what came on the 340 cars. I would look at a stock 340 car and see. For "MY" taste, even the stock 340 height in the rear is too low.
Yes, I have SS springs on my 69 340 Dart Swinger, and it has a nice look and better control for hooking up and on turns.
My big block Dart with SS springs. Ride is a little harsh, also keep in mind the 2 springs are not the same tension. They are numbered wit a left and right, the right being stiffer to counteract the torque of the motor. I had to adjust the torsion bar to get it to ride level. Hope this helps.
Well, i got it all torn down today.. Heated the u bolt nuts to get them off, along with the front hanger bolts on the drivers side.
