I will update my findings when I get back to the motor. I had to go back to work to get some rest. I'm sure some of you know what I'm talking about.
a brass wire wheel is much softer than cast iron. On Aluminum is a no-no. Get a piece of thick glass or a granite floor tile and glue a piece of 600 grit on its shiny face, nice and flat. Run this over the gasket plane a few times nice and easy and see if any area is getting missed, there is your low spot.
too much oil? the excess will run off, if way too much will scrape itself off as you drop the bolt in the hole.
Buick V6 engines are a pain in the pisser. They changed the deck surface/cooling a few times. Head gaskets and heads have to be compatible with the block. Then one year they changed from odd fire to even fire and then a few months different they changed how the distributor drive and timing gear were installed. On one the distributor gear was machined on the front of the cam. On the other it bolted on. The cam has to match the crankshaft and that requires the matching timing set. A friend built a 3.8 for his 32 Ford. They could never get it to run right. He got a camshaft from a swap meet. I have a couple of books. One on just the Buick V6 and the other looks at a number of V6 engines. This is how they figured out the crankshaft/camshaft mismatch.Easy enough to check, put the gasket on the head, line up the bolt holes check all the passages.
Use the same gasket on the block do the same thing.
If all the holes are correct it's probably not the gasket.
Maybe you have a crack in the block that opens when the bolts are tightened?
Don't some of the head bolts penatrate the water jacket and need propper thread sealer to seal?
Could it be coming from the intake?
Are you giving any sealer a day or more to setup before putting fluids in?
My ported X heads have been decked at lest once that I know of. It took around .010 to clean them up.New info everyone. Not sure if this is my problem or not. I picked up a good used 360 magnum motor this week. I measured the thickness of the heads at the corners that are machined with the mounting surfaces. The set of heads I am trying to use is .025 thinner than stock heads. Looks like they have been resurfaced before I had them done again. How much can you take off of these things before you start having problems?
So, did you get the leak repaired or find the problem?Unfortunately it doesnt run off. Excess oil rolls up the threads as you turn the bolts in, comes out the top and contaminates the clean head surface and ruins head gaskets. I like how there are pictures on line and in books showing people dipping their bolts in a cup of motor oil. Just enough to coat the threads is all I do.
The success of an wire wheel on IRON deck surfaces, only if it's not razor scrapeable , is based mostly on the operator.a brass wire wheel is much softer than cast iron. On Aluminum is a no-no. Get a piece of thick glass or a granite floor tile and glue a piece of 600 grit on its shiny face, nice and flat. Run this over the gasket plane a few times nice and easy and see if any area is getting missed, there is your low spot.
That's something because 318's head bolt holes go into water in the 80's...and pretty sure so do late model 360 rollers. Magnums do. My 96 does.Blind holes. No water jacket access.
I've got 3 that do.I've got an La 318 and 2 LA 360s and 3 360 magnums. None go in the water jackets.
Did you use the same intake gasket?All right everyone. After taking a few weeks off from cars to do spring yardwork I decided to put my big boy pants on and try this again. Same heads, heads have been shaved .025. Everything I read says that's no big deal. I cleaned the block and heads with razor blades and acetone. I used Fel Pro 521SD gaskets. No Leaks!! . I feel vindicated. My LA / Magnum hybrid lives! I will only use the heavy duty gaskets from now on. I learned some small blocks have blind holes, some do not. I learned the Fel Pro 519SD magnum gaskets and the 521SD LA gaskets have the same exact holes except the magnum gaskets have holes for the pushrods. The LA do not. Thanks for everyone's input. Hopefully this will help someone else.
