LED Instrument Cluster
APK
Springfield, Missouri
Interested in brightening up my Instrument Cluster at night on my 1972 Dodge Dart Swinger.
If I change to LED Bulbs do I need to do anything else for them to work properly?
Any recommendations on a brand of LED?
Thanks
I got the Zevo ones from the local parts store and I like them a lot. Non dimmable, but that's was the whole point. I want the BRIGHT and they are.
Remember that LEDs are polarity specific. You may have to turn the bayonet style bulb 180 degrees for them to work.
Also you will probably need to replace both flasher units with the electronic version as leds do not draw enough power for the originals to work.
For whatever reason I had to leave one of the old style bulbs (I don’t remember which one) in the circuit for proper operation.
I got some LED tail light bulbs from ‘Walley’, they both lasted approximately 1/10 of a second. Replaced them from ‘Super Bright LEDS and they worked great.
Yote
Yote
The superbrightleds LED's worked great for me too. Like you said, be sure to use a flasher with the black ground "pigtail". The "LED flashers" I got initially did not have the pigtail and they did not work. Moving to the correct flasher fixed things. I converted my 70 Duster to all LED (except headlights) and had to leave the OE style brake light bulbs in place for things to work properly. Other than that was a great upgrade.
