Lets lower your E.T.
318willrun
Utube channel 318willrun
I'm here
For something fun, I'm going to give away a Holley 650 DP and I'll pay the shipping. I bought it at a swap meet, installed and it ran but leaked gas out of the front accelerator pump. I'm offering it here and on my youtube channel.
Here is the deal, you provide me the following:
  • Previous ET slip or if you type it I need all the info.
  • engine and details (intake, carb, cam, heads)
  • transmission and converter if automatic
  • gear ratio/tire size
  • what vehicle
  • Must be willing to work/tune the carb. Fixing and tuning things is kind of what a 318willrun is....
  • Honor system, no flippers !!! Means you'll try your best to tune and work with it for your car. If not, pass it on....
In a week or two, I'll select somebody I think will benefit from the carb swap. You will try to work with the carb and hopefully we knock a tenth or three off your ET slip. Should be fun !!!
PM me for where to submit your build, and I'll get you a email address.
.... and of course, report back with the results. For better or for worse, we'll want to hear from ya, part of the fun of course!
This would give somebody all winter to go through it and get it set up for the Spring.... Speaking of us in the Northern part of the country :)
Boohoo, this would be a great idea for me but I have yet to get the Dart on the street, much less on the strip. :(
Tear that thing down, clean it, slap a proform main body in it when you reassemble and you would have a nice carb....all in less than an hour.
Probably trash in the check ball area on the accl pump.
I'm sure it's a easy fix. If somebody gets it, I want them to work with it to gain the experience and hopefully knock a little off their ET slip.
