lg bolt pattern?
rusty
Desoto,Ks
I have a friend with a 61 Valiant,he wants to go LG bolt pattern and can't find any info on how.Any ideas?
Sorry I can't help directly, but when I'm not sure I usually try the search function first.
Did you try that? Might be info in there.
The least expensive way to mount large bolt pattern wheels is with adapters.
They will bump the wheel outward about an inch which shouldn't be a problem.
Adapters got a bad reputation that was due to improper installation. They must sit flat against the hub surface. If a weight on a drum interfears they will get loose. Grinding clearence is the only option.
I'll let him know,he is a machinist and mc mechanic I,m sure he will figure something out,I just thought I would ask if there was an easy way!
