Lifespan of shock absorbers
DartGTDan
'71 Dart GT Fan
metro-Detroit
Many of our cars don't see the driving duties they were built for back in the day. I've owned my car for almost 22 years and I think I've travelled about 13,000 miles in those 22 years.
With that said, when do you replace your shock absorbers?
Do you base it on time?
Do you base it on miles?
I put some NOS gas charged Monroes on Vixen in 2019 shortly after I got her and they still ride good. I would use ride quality as the test.
The old jounce and rebound test. Bounce it and should not bounce more than twice. Look for one side bouncing different than the other side. The best way to check is to remove them from the car.
I just replaced the Monroe’s I installed 16 years go with new ones last month. The car has covered about 10k miles over 16 years. Considering new shocks are not a high dollar value item, I didn’t think twice about replacing something that’s 16 years old even if it doesn’t have a lot of miles on them.
in general they either work or they develop a fault after years of good service and die very quickly after, and its very evident as you drive, the wheel spends a greater proportion of the time NOT on the road surface.
physical damage, corrosion and leaking oil most obvious issues, gas charged shocks still have oil in them which will leak out....
and yes you can have perfectly good dampers with absolutely ruined bushes/rubbers at the mounts.
obviously if you fit dampers that are too long or so widely out of specification that you bottom them out. you can destroy them very quickly. suspension should be on bump stop before shock meets end of travel.
ie cut down springs with a standard mcpherson strut inserts don't last long
we don't have that to worry about....
spend to match your upgrades and driving ability/style/intended use
i have little ability no style and my intended use is driving to shows and the occasional squirt down the track so i buy more or less standard stuff and i still think of my 15 year old shocks as my new shocks.... :) cars has done about 10,000 miles
KYB gas ad-just are not considered a performance shock, jack of all trades and potentially master of none, but fit in the place where a standard shock once went and are an obvious seat of pants upgrade over anything that was worn out before. KYB, japanese company that makes its money making shock absorbers for planes and plant/machinery, never gonna be refined but do a decent enough job, plenty do it better but bang for buck (a set of 4) i'm happy with what i got, and will replace when they are noticeably degraded.
car run at a ride height that follows chrysler australia track spec. i.e lower than your average A body passenger car, but very much not on the bump stops at the front, correct wheel diameter and tyre side wall height. nothing drags on street/pavement features.
Dave
The jounce & rebound seems to be OK, I don't see any leakage or damage on them. I might just change them out this spring/summer, I mean they've been holding the car up for at least the 22 years I've owned it.
:thankyou:
:thankyou:
They don't hold the car up really. The springs do that. They just control the bounce.
