Yeah, so that brings me to this question bc I have a bad back and don’t wanna go to crazy the car has a 727 trans. I have the heads obviously off and the headers out of the way. What’s the best approach to pull just the engine ? A jack under the trans and undo the bell housing bolts since I can get to them all in the engine bay ?Well here would be the best advise from anyone who has been down this road .
With lifters wore that bad the metal that came off of them went through out the engine. The engine will always have that metal in it unless it is tore down and cooked clean.
The cam bearings are probably toast. so that means the engine will have to come out anyway because they get install from the rear of the engine.
Pull the oil filter and cut it open and spread the paper. I am sure it will be full of metal. When there is that much wear on a cam. It will need More then a cam. You can take that to the bank. Don't waist any money trying to doctor that engine up. You'll be sorry and that is a fact.
