Lightweight master cylinder leaking at firewall
1969cuda
California
This is the second time in 7 years this has happened. I replaced the last master with a new one, and then this happened again. Very frustrating. Does the rubber seal go bad that soon?
DOT 3
The rubber boot is dry, but misshapen.
I will do the same, unfortunate I will need to buy a new master cylinder as to not cross contaminate.
Dot 5 is supposed to be compatible with dot 3, but I understand your concern with peeling paint.
There is no pressure there. It is simply a seal between the reservoir and master. If your master is functioning and it's just leaking there, just replace the seal, if you can get it.
I had the top cap seal leak on that MC and it's not like I check the fluid every day. So what's with the seals, what are being made out of? Looking to buy the cap seal they were pricey. I went on Ebay and bought a pair of Dorman's for about $12 with free shipping. Sometimes just have to keep looking for the right deal.
