mopowers
Do you guys prefer to install your line locks on the front brake line, or on rear brake line?
.........................Front. Why would you put it on the rear? Have you got a honda?
You can put them on the back. You engage the line lock and shut the fluid off from going to the rear. You then hold the car by putting on the brake which only activates the front.
If you have to ask that question.... maybe you should not have a line lock. Lol!![]()
Assuming it's rear wheel drive you realize that you want to lock up the front wheels so you can heat up the rear tires....correct?
lol, guilty as charged!You boneheads realize if you flip the line lock around, you can block brake pressure from the rear brakes, essentially accomplishing the same thing as plumbing the linelock in the front brake line, right? The only difference is your foot acts as the "switch" if plumbed in the rears, vs if plumbed in the front.
I've done it both ways and am curious what others prefer.
Keep It Simple StupidJust hook the damn thing up the way it was designed. To the front wheels. Ever see a guy stage with the line lock and leave the line skidding the front wheels?![]()
Its for heating the rear tires at the race track...makes it easier to do a burnout. Click it on to hold the front brake pressure and let the rears go.Sorry for being a “bone head” sir but why would you stop rear brakes from working? It’s a safety thing.
I must ask because it doesn't make any sense to me, Why would you want or need to control the rear brakes during a burnout? Don't you control wheel speed with the long pedal on the right?Line locks can most certainly be installed to block pressure from the rear brakes, in the rear brake line, making burnouts easier to control (in some folks' opinion) by using your foot to control front brake pressure as opposed to having them controlled by an on/off switch. I've done it both ways on a couple cars and either way works fine.
I just checked the 2020 NHRA rules, and it appears that NHRA prohibits plumbing line-locks in rear brake lines in some pro classes, but is not specified in the general requirements. All it says is that "All line-locs (electric or hydraulic) must be self-returning to normal brake operating mode" - meaning momentary switch is required, I'm assuming. I've noticed quite a few guys at the track run them on the rear lines.
