Line Lock - Summit Brand
Anyone ever use a Summit Brand Line Lock? Summit Racing® Staging Lock Systems SUM-760000
At $70 it is 1/2 the cost of the Hurst one. Looks like a good deal.
I run one and it works perfectly.
Let me know if you want your brake lights to work when the lock is active.
(Required by law on the street)
I can save you a lot of time, money and work with an inexpensive kit that doesn’t require cutting into your brake lines and plumbing in a pressure switch.
There are others on here using my kit and are very happy with how it installs and works.
Awesome! Thanks for the info. I don't guess I need it to light the brake lights. I am only going to use it in a situation either on the track or doing burnouts, which I am sure is more "ticketable" than brake lights not working. LOL
I helped one guy on here set his up so he could throw a switch and have his horn button work as his line lock switch.
Throw the toggle switch the other way and the horn honks again.
it's not what you may expect of an anglia gasser. it's the 105e (harry potter shape) but an estate/wagon version
neil.
I've had bad luck with the two Summit line locks that I've had. First one went bad pretty quickly as did the second one...
Probably just bad luck but my experience none the less...
^^^and before the comments come in yes I did use it properly where I pumped up the brake and then set it>>>>
i have a hurst line lock and it only holds for only 5 to 7 seconds then it fades off ever since new . but i would think it should hold for as long as the button is held on ???
You still offering these kits?
That is over, sorry.
Ok. I’ve got a wilwood adjustable proportioning valve (like the one below) to install on my car. If I utilized the brake light switch in that, do you know if that’d work to keep the brake lights activated when the line lock is engaged? I’m assuming it would as long as the line lock is plumbed in between the master cylinder and the proportioning valve.
Wilwood Disc Brakes 260-11179 Wilwood Brake Proportioning Valves | Summit Racing
There is a spare/un-used port on the linloc, plumb in a br switch like this, and wire in parallel to existing brake lite switch .
