gm1236
Kent,
The k d Lever rotates a valve that controls the transmission line pressure. At full throttle, manually shifting or not, you want this lever fully applied or close to it. If this is adjusted wrong the tranny won’t shift well and eventually burn A clutch pack. It’s also activates the “passing gear”, or kickdown.
If you are using the stock mechanical kickdown linkage adjusted properly you’ll be ok. I’m trying to get full pressure and proper shifting with the locar cable. The quicksilver shifter will have nothing to do with this, all That does is move the shift linkage.
Thanks lemondana, that’s good info if I go in search of the right lever.
