themoparman73
Is there a specific way took hook up your throttle cable to the gas pedal when using the lokar throttle cable or do you need a aftermarket pedal?
It has a ball end on the pedal side of the cable, it just goes where the factory throttle cable ball end is on the factory pedal. No need for aftermarket
All,Thanks everyone, for your information
measure from the firewall to your carb.. i think the 24 fits but forget.. pretty sure you'll have to cut the 24 shorter..
I have this same setup in my 73 dart/360 with an Edelbrock carb. I can't seem to get to wide open position and then back to idle.
How close the the throttle shafts is your connecting point?I have this same setup in my 73 dart/360 with an Edelbrock carb. I can't seem to get to wide open position and then back to idle.
Marion,All,
I grabbed the 24 inch one. It's going in this weekend. 24" Seems plenty long enough!
Marion
Great! I actually trimmed 6-8 inches. I had at least initially, put a door wedge/shim under the gas pedal bracket to get WOT.Marion,
How did that 24" cable work out?
