Lokar
lenky1
illinois
Need help 71 duster 318 i need a throttle cable. Which 1 is it
Whichever one you like
The 24 incher is probably fine, and can be cut down if you prefer
no problem man
if your running a lokar kick down cable, i would imagine you want to match the two
personally, i like the look of the braided stainless version
no problem man
X2 (minus the green tape)
looks good
i take it that was before you got it all adjusted right?
can i see a pic of how you got it coming out of the firewall?
just to see how it loops
Yeah, that was just after installing it. Several months before startup.
No real looping out of firewall, just a gentle curve behind the rocker cover (/6 converted to a 360). Used the original firewall hole.
thats exactly what mine is, toss some pics up, id love to see how yours looks
(mine tends to bind)
Best view I can give with all the wiring in place,etc...
And here's the opposite angle from behind the carb...
If it's binding you may have some bends that are too sharp. If I recall I trimmed quite a bit off, it was basically the same length as my /6 cable.
