Long term experiences wiht Speedmaster Cylinder Heads PCE281-2140..
  • Long term experiences wiht Speedmaster Cylinder Heads PCE281-2140..
    Votes: 0 0.0%
    Votes: 0 0.0%
  • Total voters
    0
Charger 72
Germany
Hey
does any body have
long term experiences wiht Speedmaster Cylinder Heads PCE281-2140..
used on a Mopar Big block engine ?
I am building up an 440 RB Engine and want to built them on...
Hey Kim,
Thanks, has he ben using also the speedmaster Valves and springs,
or have they been repalced?
what might be the RPM limit with a out of the Box Speddmaster Head eg. PCE281-2140 ?
Greetings from germany.
Markus
Hey Kim, Thanks
so i have removed the valves looking at the pure casting... look s very good.
especially the inlet port fits absoutely exact to the Intake sealing, bettet then my Edlbrock E-street heads did before porting.
here some picture after "home porting"
One Question, which valves and springs have you installed.. I plan to use the Edelbrock set:
93775 - Edelbrock Stainless Steel Valves Intake, 2.20 in.
9643 - Edelbrock Stainless Steel Valves Exhaust, 1.810 in
5771 - Edelbrock Spring Seat Cup Kits
5792 - Edelbrock Sure Seat Valve Springs
9644 - Edelbrock Valve Spring Retainers
9616 - Edelbrock Valve Stem Locks
have you seen this comparison between
Edlebrock Performer RPM left and Edlebrock Victor right - simialr to Speedmaster Head PCE281-2140
i am courios how the engine will work with that setup
- 451cui RB
- CR=10.5
- Speedmaster Head PCE281-2140
- Edelbrock Performer RPM Intake
- Edelbrock Performer RPM CAM Duration at 050 inch Lift: 238 int./246 exh.
- Hooker Headders
I've got speed master Aluminum Heads on my 70' 340 Dart... Its not like it's a race car but I run it pretty regularly on the street and not always so easily and it does very well
I can't give any drag race times but I've had alot of cars at the track and it feels like very low 8s in the 1/8 mile atleast... no problem at all after over a year... I bought them bare and it's got comp cam spring & retainers... all good.. I think thier good heads long as your not stressing the cast aluminum with huge camshafts and big spring pressures...my Dart is only a 4.70" lift comp cam...
